Starting Problem
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
deeultiamate
Car: 2008 Nissan Versa
I bought a 2008 Nissan Versa back in 1/08. It has less than 1,000 miles on it. I am now having a problem with starting it. After it has been run for a while, it is very hard to start. You have to crank and crank in it. Also, when it gets like this, the AC doesn't work well. Anyone having this problem and what is the solution? :
fjwagner
Car: 2008 Nissan Versa S et al
there is a known fuel pump issue that I thought had been corrected. I had mine replaced under warranty. Definitely worth a call to your dealer.
Return to “Versa Technical Discussions”
