Starting problem???
TougeChallenger
Car: 91 240SX
Hey ive been having a problem starting my SR. I turn the key to go start it and there is nothing. Some times the start will click a few times and then it will start, but most times there is nothing. It sounds like a ground problem, I fixed the ground on the starter and still nothing. Could this problem be some where in the steering colum/ignition?
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
make sure you have 12 volts at the large wire to the starter. if so check to see if you have 12 volts at the solenoid wire when trying to crank it. if both have 12volts you need a starter.
khooper
have you already check if the battery is still ok?if yes probably it is the starter.
TougeChallenger
Car: 91 240SX
Ya i tested the battery and its still good. And i already replaced the starter but it still doesnt want to start.
TougeChallenger
Car: 91 240SX
Got it fixed,it was the blue relay near the battery.
