starting problem
tony/ka24de
I was checking my timming when I dicided to turn my car off, disconnect the tps sensor, and then start the car agian. But it didn't want to start. So I plugged it back in and tryed to start the car again. Still didn't start. I figured the starter was fried, but thats not the case. I checked the main power to the starter, and thats fine. I checked the signal to the starter and that seems fine. The batt is good. I don't know what else to check. I need to know everthing about the starting circut. I need to know if I missing something. Isn't the starter suppost to get a crank ang signal. I need some help. Anyone know where I can get starter circut wiring info?
SpeedRacer1
Car: 1990 240SX, G35
Try checking your ECU for codes and resetting your ECU.
tony/ka24de
It was just a corroded ground wire from the battey to the frame of the car
