sleeepy240 »
https://forums.nicoclub.com/sleeepy240-u63740.html
Fri Apr 18, 2008 1:41 pm
i fix the power problem i had, but now when i go 2 start the car the starter windding sound, but the engine does not crank. the starter is gud i had them test it before i left the parts store. i manualy turn the engine nd its feel rotates perfect. i even took the starter off nd used a big *** flat head nd manualy turned the flywheel nd when the flywheel rotated so did the engine so i know thoughs r still 2gether. anyone has any ideal what could b the problem it would b muchly appreciated. does any know if there r different starters for the 5spd & the auto?
