mohit_s »
https://forums.nicoclub.com/mohit-s-u81399.html
Tue Nov 20, 2007 1:07 am
I bought a 2000 infiniti g20. Prior to purchase, I had a full mechanical check-up. There were a couple of oil leak recommendation. Nothing that bad. However, the very next day, the car stopped starting. Only thing I had done after getting the car was a few miles and filling the gas. I took it to the same technician who did the mechanical check-up. He diagnosed it to be a problem with starter. That didnt solve the problem. He changed the fuel pump then (he was not getting fuel). But that too didnt solve it. Finally after a lot of diagnosis he figured that the injectors wont spray and are not getting grounded to open up. He has checked all possible electrical stuff and found nothing wrong. Now he thinks that it might be a problem with the ecu not sending the correct command and so recommends a new ecu. I am at a COMPLETE FIX! PLEASE PLEASE HELP!!!!!!
