OK SO I HAVE A 1989 240SX WITH A REDTOP SR20DET,I CAN NOT GET IT TO EVEN CRANK I HAVE TAKEN THE STARTER OUT JUMPED IT AND IT WORKED FINE, PUT IT BACK IN AND I HEAR IT CLICK BUT WONT CRANK CAR. CHANGED ALL FUSES AND CHECK RELAYS AND GROUNDS, TURNED ENGINE OVER MANUALLY TO SEE IF STARTER BECAME DETACHED FROM FLYWHEEL BUT THAT WASNT THE CASE EITHER, TRIED PUSH STARTING AND CAN HEAR A LIL CRANK BUT WONT ACTUALLY START...LAST THING I THINK IT COULD BE IS IGNITION SWITCH OR CLUTCH INTERLOCK, WHAT DO U GUYS THINK ANY IDEAS WILL HELP....THX
