Starting problem. Please Help.
xilovelsdx
Hey I keep having trouble with starting my ka-t car. It seems like sometimes it starts on the first try and then other times it wont want to start at all. Ive been priming the fuel pumps twice now and it seemed to be starting up better. But now its not wanting to start at all. Ive tried priming it once and priming it twice and its just being stupid as ****. I checked my fuel pressure and it drops from around 40 to 20 in about 10 seconds after the car is shut off and then very slowly drops barely at all after that. I dont know what the problem could be.
Today i stalled out and it wouldnt start back up. I tried starting without gas and then tried with gas. It sputtered once and that was it. The only way i got it to start back up was to push start it.
Im about to check my plugs when it cools.
Here's my setup
95' KA24DE MotorAEM ems w/wideband (1600U)AEM 5 bar mapKoyo SR radiator.Arias 8.8:1 compression pistonsCometic metal head gasketARP Studs95lb/hr injectors (1000cc)XS ENGINEERING IntercoolerSC61 Turbo A/R .70Ramhorn Turbo Manifold38mm wastegate-8 Fuel Lines (all around)2 Walbro 255 Fuel PumpsNGK Spark Plug WiresNGK 4554 COLD PLUGSXS fuel pressure regulatorMSD 6ALMSD Blaster coil
Thanksss
xilovelsdx
wow thanks for all the help.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
bump
