alex288 »
https://forums.nicoclub.com/alex288-u30541.html
Mon Mar 05, 2007 7:36 pm
Ok I have a starting problem that I cant fix. I have been trying for quit a while. never had this problem until I replaced my clutch. now I cant start the car with the key. every time I turn the key it doesnt do anything. sometimes it will click the soliniod and sometimes it will crank it over. I already replaced the starter. still does the same think. now pretty much every time I start my car I have to use a screw driver and jump the terminals on the starter. I did a volt check while the key was in the start position. I found that the bigger wire that connects to the starter has 12.4V going to it. and the smaller one only has 6.2V. now I am just guessing that is where my problem is at. the only thing is that the smaller wire goes into a big harness and I cant trace it. so if anybody knows where this wire goes. or just knows what my problem could be. please let me know. I have been working on this for the longest time its not even funny. so I am guessing that the low volts on the smaller wire is causing my problem. but I have no clue where that wire goes.
