Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Sun Sep 16, 2007 5:24 am
I do not know the brand of starter. I am the original owner and paid someone to replace it with a new one (over$300) in 1998.
I checked the 2 side connectors coming off the positive post and they were so dirty. Not like corrosion but like a muddy liquid. I cleaned then to the best I could, might get some brake cleaner to get deep down in the socket today. Anyway that seemed to help it start more often without putting +12 to the solinode. But then it starts to click again and will not start
When I check the voltage at the plug that goes into the solinode it is +12 with the key turned but if I check it connected inlkine to the solinode it is like 6 volts when the key is turned and will go up and down to 4volts after a few cranks and then raise slowly to a higher voltage +9 or +10 and then it will start without any clicks a few times and then the clicking starts. Something is causing that 12 volts to go down once it is plugged into the solinode.
I am so confused with that problem, Could that be a error in rebulding the starter? They just changed the solinode and some clips. My guy that rebuilds alternator/starter was out till Tuesday and my neighbor brought me to have the starter rebuilt from a old place that looked like it was the 1940's. I live in New Orleans so I do not know the history of the shop. He charged $85 cash only.
If something is bad inside the starter would it cause the voltage drop? But if that is the case it starts everytime with me just injecting +12 from the battery to the solinode without a voltage drop.
I am about to just bring it in because I am getting annoyed. Maybe I will try a new battery clamp. Mine is original from 1990.
I do not think I have any ground wire to the starter. My friend took the started off and it just had the main wire with the boot and the plug coming off the solinode. I will go under and look the starter & connections.
It is really acting the same as before I had the started rebuild & now have a new Battery. So really I did not accomplish anything.
THANKS FOR ALL THE HELP
