ka24e510 »
https://forums.nicoclub.com/ka24e510-u23202.html
Thu Jan 13, 2005 6:39 pm
to test this system properly it will take 2 people so have a buddy standing near by. you will have one person hold the key in the start position and have the clutch pressed, the other person will take a screw driver handle and smack the blue starter relay, if the car starts cranking, its the relay. if not, you will need a test light. have the one person still hold the key in the start position/clutch pressed and check the signal wire at the starter(black with yellow stripe?) and see if the test light lights up. if not, you have an electrical problem. if it lights, then smack the starter with a long hard object or crawl under and smack with a hammer. when the car starts, you will know that the peice of crap autozone starter is no good but only when it gets hot and locks up but when it cools down it will always test good. if that is the case, replace with expensive dealer unit and pay the core charge. if it was something electrical, take the car to the dealer and pay the diagnosis charge, it will save you alot of money in the end to pinpoint the exact issue, then you wont have to throw a bunch of parts at the car spending hundred's of dollars to not fix it.
