starting problem. I can't figure it out.
tony/ka24de
I was checking my timming when I dicided to turn my car off, disconnect the tps sensor, and then start the car agian. But it didn't want to start. So I plugged it back in and tryed to start the car again. Still didn't start. I figured the starter was fried, but thats not the case. I checked the main power to the starter, and thats fine. I checked the signal to the starter and that seems fine. The batt is good. I don't know what else to check. I need to know everthing about the starting circut. I need to know if I missing something. Isn't the starter suppost to get a crank ang signal. I need some help. Anyone know where I can get starter circut wiring info? I have the sr swap.
benemorius
Car: s13, s13, eg, e36
What does it do when you try to start it? Not cranking or not firing? What engine is it?
slydin'240
Car: 1993 240sx Coupe, 2003 Maxima SE
I guess you could try one of these service manuals. It might have what you're looking for.
http://www.zeroyon.com/index/content/view/24/47/
mss5413
Car: Nissan 240sx
Check the rubber stopper on the clutch pedal. It is suppose to close the switch when the clutch pedal is depressed. If there is a hole on the left portion of the clutch pedal arm then you need a new stopper. I will keep you posted with more ideas.
