Starting problem, help needed!
J30Guy612
Car: 1993 Infiniti J30
Hey guys when I start my car in the morning, after it has been sitting all night, I have been having some problems.
The car never starts on first crank. Sounds like it has plenty of juice as far as the battery and starter go, but just doesn't turn over and actually run.
Usually what I have to do is crank it for about 5 seconds. Stop. Crank again for about 5 seconds, and repeat this 4-5 times before car turns over and starts to run.
When the car does start to run, it runs at a really low RPM for a few seconds, and sort of chugs along, until the RPMs pickup and it runs smooth.
I don't have this problem when the car is warm, only when it's cold.
I don't think it's freezing of any kind, as temperatures have only been around 10-15 degrees.
Any ideas?
Thanks!
tony11
Hello , im woundering did you fiqure it out yet ,im working on a 97 now and have the same symthems , I changer the iac unit and no change and checked the iac regulator its ok , im looking at the mass air flow now , trying to get the speckes on it now , wount you know the book is not in the trunk , let me know , im also getting a po505 code , im trying to figure it out , Tony
