starting issues with my sr
prophet180
Car: 1989 240sx SR
okay i just got my swap done but i'm runnin into a issue my car won't crank on is own. its gettin fuel and its sparking correctly but it will not crank the only way it will crank if you spray throttle fluid in the rail it will start i even check fuel lines it's all good. ANY SUGGESTIONS ON WHAT IT COULD BE!!!!
skateboardstan
Car: 92 240sx T28 SR
sounds like a wiring problem. maybe your fuel lines are crossed...thats what happened to my buddy. if not reset the timing. good luck.
nxpoweredsr20
Car: 95 240sx w/sr20 swap, nx wet shot, t4 turbo, shop car
my guess is reversed fuel lines.....little problem that happens to alot of people ...switch them and let us know
