First off, i am runnin sr 370cc injectors, safcII, and a walbro 255 on my na ka currently, preparing to install a turbo soon. I installed this to work out bugs, and i have one so here is my issue/question
I installed the safc and ran it for about a week or so to make sure it was working correctly. And then I installed the 370cc injectors , made corrections of -27% across the board. The car will start fine at cold start in the morning after sittin all night, and will start up if it was just recently shut off. But in the period we'll call warm, it has trouble starting, 1/2 hour to a couple hours later, and needs help to start. Thinkin i may have had an injector leak, i picked up new orings from nissan pulled the rail again, installed the injectors, and then built fuel pressure to see of any leaks. None were seen. Put it all back together, same issue. Car starts right up when sittin for larger amounts of time (overnight or after a 9 hour shift of work) and when just shut off, but not after a bit of time. I have to essentially floor the pedal to start it (indicating to me that its flooded) The plugs were rich fouled and where switched to differnet plugs when the new orings were installed.
So, now im just tryin to figure it out, possibly a bad injector? When its tryin to start the motor shakes a bit, making me think a cylinder is flooded, but once it starts i get a lil smoke (smells like gas, goes away right away), then it idles and runs fine, with no smoke at all.
If so, any advice as to isolate a bad injector? Sorry bout the novel, just people like details on here so i figured id cover everything. Oh and this happened the same b4 and after the walbro install, so that is a null factor.
Thanks in advance
Adam
*edit* Just a lil more info, i just pulled all the plugs and they all appear the same. The only thing i noticed between the 4 cylinders is possibly a very faint smell of fuel in #2. So, do u think i should pull the injector again and drop it back in and see if it was sealed properly? switch it with another cylinder's injector?
Just lookin for ideas.
