starting issues
Maxi
Car: 1995 Nissan Maxima
My 1995 Maxima(Maxi) will start when she is cold, but when she starts to warm up she will cut off unless i feed her gas. After i feed her gas and rev up the rpms for about 30 seconds she will idle high then return to normal. I will repeat the process 1 or 2 more times then once she is warm i can drive. If i cut her off and then try to start her right back up she will not start again until she is cold again. Can someone please help me. Have changed the crankshaft sensors, camshaft sensors, starter, spark plugs, and the battery. Can someone please help me. :confused: It is a 5 speed.
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
It sounds like an EGR issue. The 4th gen is known to get clogged EGR guide tubes. Are you getting any codes? Hoping this is an OBD 2 car but chances of that are slim. Im at work at the moment but I'll post the diag process from the FSM on the EGR later.
Maxi
Thank you for your reply. I will wait to hear from you again.
Dattebayo
EGR?
Well, I don't think so. It sounds like a Fuel Pressure Regulator issue to me.
