starting issues
ka671
Car: 93sx
1. in the morning it wont start. I always need to prime it w/starter fluid.
2. after the initial start. if i shut the engine off, i need to wait about ten minutes for it to restart w/out priming.
other than this my car runs fine, but stoping by a store on the way to work is frustrating.
most of the emissions have been removed. see my sig for details on the car
any ideas
Koukiman654
Car: 1998 240sx
Sounds like a bad fuel pump. Fuel pumps are not supposed to let the fuel drain back to the tank after shut off but it seems yours is so I would say a bad fuel pump. The only other thing I can think of is a seriously leaking injector or a fuel leak (which you would smell fuel outside of your car after driving it) Hope everything works out for you.
modulation
Are you AFR's normal on startup?
Perhaps your coolant-temperature sensor is the problem?
When you try to restart it how are the AFR's?
