nsxon19s wrote:Thinkin its starter but battery terminals i hear are problem.
Definately follow Tech's advice and have the alternator tested. Autozone and a lot of other parts stores (my local Napa) will check it for free. A bad alternator kills a battery and vice versa. Sort of a lose-lose situation if you let problems with either go on for too long.
Since you mentioned battery terminals (clamps) take a close look at those connections also. The clamps wear out, holes in the connectors corrode, and before you know it the clamp doesn't tighten enough to get a good enough connection to engage the starter but everything else in the passenger compartment works. I speak from experience having replaced my starter after hearing the "click, click" when the only problem was a marginal positive terminal.
