driftjunke »
https://forums.nicoclub.com/driftjunke-u15361.html
Fri Jan 20, 2006 7:21 pm
Alright, maybe somebody else has run into this when swapping in a S1 RB25 into a S13. Little info on the car, swap was done by another shop, left plenty of bare wire, didn't connect any gauges, no fans, half assed all the way. Anyways car was brought to our shop not running, apparently overheated, blew the headgasket, burnt up the oil and continued to drive needless to say the engine was dead, and wouldn't fire just turnover. We rebuilt the motor, reinstalled it using a new harness, previous was thrashed, and wired it up ourselves. Motor was originally an auto but converted to 5spd, but had a manual harness, which we swapped out due to its condition and used an auto 25 harness. Now the issues is, we get air, fuel, and spark, its just it turnsover for about 30 seconds trying to catch and fire up, takes a couple off tries, still stock fuel system with walbro. I swapped out CAS and the ignitor chip, and it cranks a little easier, sometimes. You can smell the gas when trying to crank and it eventually cranks up. Sometimes though it will fire up first try, cranked everytime about 15 times in a row, let it sit for an hour and no fire up, just turns over trying to catch.
It seems sporadic the ways it acts, any ideas anyone? Checked about everything i could think of, still no luck.
Thanks
E
