starting issues 94 240sx
cramsey96
Car: 1994 nissan 240sx red convertible
I bought my stock 94 convertible 240 on April 20, 2013. I paid $1850 for it. The brakes were pretty bad and I didn't have the cash for it at that time. The car sat until july 1st.
Once I got it back bit on the road it didn't want to start. Ive checked the battery and starter and those are still good. I changed the spark plugs today and still have the same issue. If I let it sit I can start it and rev a little then it will be fine to drive, once I turn it off and try again it won't budge. The engine will turn over just not engage. Any suggestions?
cramsey96
I made this video this morning after it sat over night. Hopefully it will explain the problem better.
http://m.youtube.com/watch?v=GdFFXtaRS7U
Nismoholic
Car: '91 240sx SE Coupe
'95 240sx SE
Besides plugs, have you done any other maintenance to the car? Maybe get some starter fluid and on the second crank attempt, spray a little in the intake and see if the car fires up. That'd at least tell you there's a lack of fuel or if it's spark. The video looks like a fuel problem, but I'm no pro. /shrug
acslater9
What's going on cramsey96, I had the exact problem with my 240sx, I was told that It was my CTS(coolant temperature system) so I replaced and It worked.
So If I were you change the CTS and give us an update I got mines for like 17 bucks brand new.
turbocarslut
Car: 1989 Nissan 240sx (hatch)
2011 BMW 535xi
is the fuel in the tank the same from April? Fuel does not store well....
