Starting issue
abnrjd
Car: 2004 nissan path (LE)
I have a 2004 3.5L LE Pathfinder, I drove the vehicle to the store, everything was fine, when I went to leave it would not start, just a click. Checked the battery 12.47V. Battery terminals/connections were tight. As I was checking over it after sitting for about 15 minutes, I tried to start it and "WAALA" it started. Need some insight what could cause this problem please. I understand there are three components involved in the starting, Alternator, Starter and of course the battery. Any ideas would be greatly appreciated Thanks.
AlanAZ
Car: 2003 Infiniti QX4 RWD
I've wrestled with starting issues lately, but no crank and no click, which wound up being the starter relay. That you're getting a click, implies to me that you're getting power to the starter motor. I'd check in the direction of the starter motor first. (and that it started after nothing but a click earlier, indicates that the battery and alternator are good)
