Starting issue...
SRS14a
Car: Kouki S14a
Hey Nico! Quick question... When I crank over my redtop SR a Screeching noise comes from my starter(or that area)... Ive had my Kouki for 8 years, and I've had and see starters go and its never sound like this... Is this the starter going? I know starters will grind on the flywheel, but its not a grinding sound... just a Screeching high pitch noise. any input would be awesome! cheers!
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Did you have somebody try cranking it while you listened or just from in the car it sounds like that area?
SRS14a
Car: Kouki S14a
Both, its coming from that area, it starts right up, i think it didnt start once... its ridiculously loud...
Sideways570
did you put a new starter in recently, because it might be a clearance issue or it can be a bearing issue on the alt. just throwing in what i can hopefully it points you in the right direction
SRS14a
Car: Kouki S14a
I haven't replaced the starter, but I'm running a KA alt wih a SR pully, ill pull the belt off and try a start up, see if the screeching happens. if not it might be the alt... Thanks for the input Sideways570
