mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Sat Oct 29, 2005 6:17 pm
Ok
I tested the relays under the battery and they are both good. I decided to pull the ECU out so that I could see if I was getting any codes from there so I checked and I am getting a code 16 and 34. The 16 has to do with the TCS and the 34 has something to do with a detonation sensor circuit. I erased the codes and started the process over again after I let the engine run awhile and I got the same codes again. I also still have an issue with the starter hanging for 2 to 3 seconds after releasing the switch. I tested the starter relay (at least I think I did. The book called them ignition relays 1 and 2 beside the fuse panel under the dash.)and the only thing else I haven't tested yet is the starter solenoid which I feel is going to be a pain in the ***. Now I did pull both of the ignition relays at the same time and while they were out I wanted to see if the car would still start. Well, It started so I don't know what these ignition relays actually do.
I still don't see how that the starter hanging up could cause the TCS and SLIP lights to come on. Has anybody else here had this same problem and if so what did you have to do to fix it if you were able to? I don't know what else to test on the TCS. The TCM behind the glove box is telling me that all is good. I don't know. I am almost tempted to bypass the TCS all together.Like I said in my last post, If I turn the car off and start it again the ligts will go out.
P.S. If those relays that I pulled are not for the starter then can somebody tell me were the starter relay is? thanks
Matt
