Do you hear a click or any noise when you try to start it? How do you know the battery is ok, have you charged it? The main battery fuse is ok? All your other accessories/headlights are working? I would be leaning more towards the starter relay failing before the starter dying. You will have to check for power at the starter itself. This may mean jacking the car up in the air to crawl underneath. Also could be the ignition switch.Glacier90_300zx wrote:Ive had my 300 for awhile now and never had a problem i have XXX subs hooked up and had no problem but now all of a sudden my cars now starting its not even cranking. my battery is fine plenty of juice and im pretty sure all my fuses are ok. the only thing i can think off is my starter but i dont know if a starter can jus cut out like that it took a day to fully not be able to start. is there any other thing that could be wrong?
did you test for voltage at the trigger wire?evildky wrote:the main relay is located inside the drivers side fender liner
befre you go pulling that test forsignal voltage at the starter trigger wire, if you get signal voltage it's a bad starter
