starting issue - not starter or battery
LostAndFound
Car: 89 SOHC 240sx
91 240sx stock ka24de
Suddenly one day my car stopped starting, there may have been one day prior that it had a tough time starting. I felt certain it was the starter, so I replaced that with a brand new one, and also had a new battery. Car still doesn't start, can't get jumped, but I can push start it.
Any other recommendations what this can be? What I gather is the blue relay or the small switch by the clutch pedal. ALSO, what additional fuses/relays should I double check?
I read on the blue relay by the battery to jump the brown/white to brown/yellow to test if this is the cause, can anyone verify?
For the switch by clutch pedal, if I loop the two female slots, will that bypass the switch to test that?
WDRacing
Can't you test the clutch switch by depressing it and checking for voltage on the output?
As far as relays possibly being bad, I usually opt for just replacing them with brand new ones if they are in question.
WD
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
There are a lot of places that can go bad from the key all the way to the starter. Your best bet is probably to get a multi meter out to test everything. The FSM has a good diagram in this section starting on page 12. http://www.nicoclub.com/FSM/240sx/91-94/EL.pdf
WDRacing
Agreed. I was always lucky starting at the starter and working towards he inside. Multimeter
