superDorifto »
https://forums.nicoclub.com/superdorifto-u29662.html
Fri Jul 27, 2012 8:59 pm
I'm looking for some input before I start tearing into my s14 in the morning.
Background:
97 ka, stock electrically except for an optima yellow top, and my stereo.
The battery came outta my GTO, and the terminals are on the opposite side...meaning the hot lead is a bit tighter than I would like it.
A few months back the brake light and battery light came on on the way to work (my understanding is this is an indication of a failing alternator, or wiring issue) it was rpm dependent, meaning the light went away after accelerating.
But after checking the wiring to the alternator, and letting the car sit for a night, it went away....no trouble codes our anything since.
Earlier this week I meet up with sDaigle, and noticed a wine or whistle, that I thought was a bearing, either the alt, carrier, or something in the transmission. I joked with some friends that if it was the alt, id know sooner rather than later
This morning, I noticed that my music was skipping, only it was playing off a thumb drive. The volume on the radio then cut out. A minute or two later, the radio started turning off and on of its own accord. At this point I was at work.
It sat for a few hours, when I went to leave, it would start, but not idle...which it has never done. I manually manipulated the throttle, got it going, and headed to my last meeting. The radio issue presented in the same way, in the same order...skipping, volume, power. Once I parked at my destination it refused to start again. I can hear the starter solenoid firing, but there's not enough juice to turn it over.
Im going to start with the alt, battery in the morning, but wanted to see if anyone else ever had the same radio issue. The radio harness is wired properly, and the subs/amp all have the proper cables, fuses, grounds and whatnot.
Any thoughts?
