starting help!
slipnslide240sx
Car: 240sx
ok i have some 370cc sr injector two of them didnt have pintle cap the brown plastic thing at the end of the injector. i read on the forum that it will work with out them so i remove my old 270cc injectors and broke one of my own pintle cap. so i put the sr injectors in and car doesn't crank?! i rempoved it and put the old ones in with one of the injectors having a broken pintle cap and it wont crank either? i need help
i'm sorry the car cranks but wont start? i just read on more forums and they say its fine to run with them so why doesn't it start?okay so i think it could be a fuse but i check all the fuses and its fine? is there any othere fuse location for something to do with the starting?
jdmnate
Car: 93 240sx
mine was doing the same check cap and dizzy then advance toyr timing alot if no help mix up spark plug order .....like move 1 to 2 2 to three so on
