fyneyoungstunna »
https://forums.nicoclub.com/fyneyoungstunna-u18200.html
Wed Jun 29, 2011 10:32 pm
Well im just comming from doing the water pump stuff, and the injector replacement after that.
On the first crank from hooking everything back up it wanted to start but would not turn over. Tried again an it turned over for a second and then died.
Its acting like its not getting fuel, but i can hear the fuel pump prime when i turn the key.
I can think of two vacuum leaks right off the back of my head. BUT, i did the delete of the stuff under the plenum, the two lines are under the throttle-body and they face inwards. My ptu is fine, as i cleaned and checked it first thing.
only other think i can think of is I might have pinched an o-ring, but there is no fuel smell from under the hood. That and the actual connectors going to injectors and coils. I tried wiggling those while it was being cranked over but it didnt change anything.
Also, could it be out of time since I took the crank off for the water pump stuff?
ok gotta update a little bit.
she starts and will stay if i hold the gas down so i'm thinking i just gotta redo the injectors.
I have a brand new plenum gasket on there, if I take off the plenum will it be ok?
