We stock RB26's and perhaps will save you some money...
http://shop.rawbrokerage.com/p...d=227
I believe we are the only place that will seperate the AWD transmission from the motorset and give you credit towards a RB25 transmission.
List of parts for a RB26 swap:RB26DETT motorRB25DET Transmission and push type clutchMounting solution (either conversion mounts or crossmember swap)Conversion driveshaftConverted engine harnessFMIC with custom pipingConverted TachometerModified Oil Pan
If keeping bottom mount twins (stock or aftermarket)... you'll need a custom downpipe to clear the steering column.
That list is a rough spoon feeding of whats involved in getting the motor to be properly mounted in the car and turn key running.
For insurance like mentioned before... like any used engine (especially if you are spending this type of money on a swap) it's advisable...
General Maintence & engine prep - (spark plugs, fuel filter, belts, gaskets, filters, timing belt and related components, etc.)
Do this and you AND your engine will be happy.
If you are still up to the task, I can help you along the way as well provide you with ALL the above parts and know how.
Need some inspiraion or step through on a RB26 into a vert?
zerothread?id=390042
The RB26 might be or might not be what you are looking for but thats for you to decide not us.
What I like to suggest to people when they ask "which engine to go with?" is...
figure you budget for such a swap as in how much you have to spend or willing to spend.
Figure the type of application you wish to use this car for (street, road, track, drift, drag, etc, etc, etc.)
research, research, research the engines you might potentially swap. much is uncovered in this step.
Make a grid, matrix, cost vs. benefit analysis, etc. etc. whatever fits your decision making process.
Determine what engine best fits your needs and budget.
Re-evaluate budget.
multiply by x2.
Then call me
