GuSpeed wrote:I saw a video of some guys starting a RB20DET sitting outside the car not installed. How can you do this? Is it possible to compression test if you can do this?
Does anyone know how I can do this? Thanks.
if you have a front clip then all you need is a fuel pump, battery, and fluids (oil, coolant or water, gas, and clutch fluid... well no you wont need any clutch fluid) just hook the battery up, make sure there are no blown fuses, level the clip so you dont get any oil starvation, hook up a fuel pump, and start it up.if you dont have a front clip then itll be a little harder. youll need the engine/ecu harness, everything i said above, someway to level the engine out and hold it, and more.
