Darius wrote:Most will recommend an OEM oil pump with crank collar. I run an N1 and haven't had any issues. But yes in general, you'll need to do the usual rebuild stuff like honing the cylinders, milling the block surface, milling the head surface, new head gasket (not Cometic), new gaskets all around, etc.
Alright, notes taken and lastly, what's your opinions on heat management in terms of coatings? (yes I know it's money that could spent else where but I believe managing heat could help alot with longevity of this set up). And also, port matching and extrude honing the exhaust manifold?
