sleepsilvia »
https://forums.nicoclub.com/sleepsilvia-u37753.html
Mon Jul 14, 2014 1:11 pm
I'm having a problem with my 93 240SX. The car won't start unless its jumped off, otherwise the starter clicks rapidly. It will run fine for a short time but the idle is a little low, but then it starts acting sluggish and the tach and speedo jump around. When I brake the rpm's dip down very low and dies. When I remove the ground cable from the battery it idles a bit better but dies once I push in the brake pedal. It has a new battery ground cable and new positive terminal. Any help would be great, thanks.
