Starting and dist timing help
Axoure Dragonkin
Car: '92 Nissan 240sx se
I just bought a 92 240sx automatic coupe with 108xxx. I was told that it needed a battery and the distributor to be timed and a head gasket. I was told the car had only been sitting for 3 weeks.
My plan was to get the car running so i can do a compression test and then replace the head gasket.
I went ahead and bought a new battery and the car cranks hard. I followed the guide here on how to time the distributor. I am getting spark on all the plugs. II can also feel the fuel line pressurize. I just can't get it to run...
Am I just not getting the timing right? Or is there something I am missing, like a blown fuse somewhere? I haven't pulled the injectors yet, could they be the source?
Modified by Axoure Dragonkin at 9:01 PM 6/8/2008
Axoure Dragonkin
Latest after playing with the distributor...
Turned key and I heard a audible pop. Tried again got an softer pop. Pulled distributor rotor and rotated randomly. Turned key and I think it ignited low on the compression stoke. Basically sounded like it slowed the rotation down on the motor.
Will be back with more.
Axoure Dragonkin
GOT IT STARTED!!!!
Took it for a spin. Slow on acceleration. Do it still need to adjust timing? Or is it just the gasket?
Axoure Dragonkin
started tearing it down. anything to watch out for while i'm in there?
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
Axoure Dragonkin wrote:started tearing it down. anything to watch out for while i'm in there?
Might be a good idea to replace the timing chain if you're going that far with it and also check to see if the block or head mating surface have warped at all.
Axoure Dragonkin
i don't want to remove the front cover this time. it would be a different story it i had the motor out and was doing a full rebuild. surfaces are within tolerance.
i was more wondering about any known issues or problems to fix a head of time. my 89s timing chain ate a hole through the coolant passage, i am so far unaware if the dohc has any similar problems
