starting an engine build
aknight_sa
Hello,
i have a 1993 300Zx with a VG30DETT engine,
i am planning to do a complete rebuild of the engine and want it to be able to produce around 600hp...
i need your suggestions of what parts to get and from where..
Thanks
aknight_sa
also i forgot to mention that i already bought the Garet GT725R Twin turbos
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
vulcanrush
Car: 93 300zx n/a to tt
probably wanna upgrade the pistons and rods?
i would probably go with kyle at importpartspro.com and not get a headache (not to mention lots of stress) that i got.
Pieceofsand
Car: 91 300zx Twin Turbo
lol I like how that 600hp pack comes with a Z1 decal.How much are you planning on spending OP?
car nut
Car: GT500.
vulcanrush wrote:probably wanna upgrade the pistons and rods?
Not necessary. '90's Nissan motors are straight beasts. You'll be near their threshold at 600hp, but a rebuild wouldn't be worth it unless you wanted 700+.
FastQuest
Car: Nissan Quest
Sweet project !
vulcanrush
their rods are strong, and so are their crankshaft and small-block, but the pistons are the weakness - it's not forged.
600whp? a friend of mine cracked pistons and is having a rebuild.
to each his/her own, but i wouldn't do it. strong engine, i agree.
but i wouldn't tell somebody to do something i wouldn't do.
i wouldn't just buy that z1 pack and expect 600hp --- bearings are important, arp studs are a good idea also. upgraded radiators and oil coolers are also something you should consider.
i'm VERY surprised z1 didn't include a howe radiator as part of that package, AND an oil cooler.
car nut
Car: GT500.
Are the pistons really not forged? I'm pretty sure the crank/rods are. Regardless, forged pistons are good but they're not great. Ever hear a set on a cold start? They slap for a good 20 minutes lol.
You know how your buddy cracked his piston? If it was under normal use I'd be surprised but it seems more likely that he either overrevved/boosted or his motor was a little tired.
vulcanrush
car nut wrote:Are the pistons really not forged? I'm pretty sure the crank/rods are. Regardless, forged pistons are good but they're not great. Ever hear a set on a cold start? They slap for a good 20 minutes lol.
no, the pistons aren't forged, but the crank and rods are, you're correct sir.
forged pistons are almost a prerequisite for 600hp...piston-slap isn't for all forged pistons, for example, CP's are pretty good...JE's are notorious for piston-slap, on the other hand. and 20 minutes is a slight exaggeration
it's how you spec the pistons, anyway.
it's a strong engine, i think of it as a poor man's supra/skyline engine...but to double the power is asking a lot without rebuilding it.
car nut
Car: GT500.
Yeah, I see what you're saying, I'm just trying to point out that a rebuild is a ton of work/money and if you don't plan on pushing past 600hp, you might as well stay stock.
vulcanrush wrote:it's a strong engine, i think of it as a poor man's supra/skyline engine.
. Anyone who says a VG30DETT is better then an RB26 or a 2JZ is a little shortsighted, but it's still a pretty impressive motor. If only it were a bit lighter, I'd say it could be mentioned in the same sentence.
vulcanrush
i apologize if i came across the wrong way.
i fully agree with what you're saying, car-nut.
i tried to do a rebuild, but it's crazy-expensive and very stressful - - - i went with a local machine-builder instead of let's say, Kyle over at ipp, and it is stressful because he's not familiar with nissan's.
i think you can run 500hp on a stock block, with good tuning, cooling (koyo, howe, etc.), and something like a water-spray system wouldn't be bad either.
