Starting a New KA FAQ
WDRacing
This forum lacks a decent FAQ to pool our resources. I'm going to start building one out of all the useful threads and commonly asked questions.
If you guys can link me to good threads or have idea's to add please do so. This forum will only be as good as we make it. For a hint on what I want, look here KAT FAQ
Thanks for the help...
WD
WDRacing
Just add links as you find them, I'll go through here and build the FAQ.
KA Cam Discussion
WDRacing
ECU Codes
neverlift
I seriously was just about to ask you in the venom400 thread if we could get a faq going to stop all these wastefull posts about is this good or does this give me... and how do I... you get it
I know I have answered many questions over and over. About time...
WDRacing
I'm going to be looking for threads that say how much power was gained by what mods as well. If you know of any, link drop me please.
WD
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
We can use a FAQ page on how to make more power with OBD2 intake mani's on the OBD1 KA engines that use the scv manifolds.TB coolant bypass FAQ page, and include the information needed for people in colder climates that cannot do this mod and explain why...... FAQ page on the wide range of OEM pistons that can be used for a high compression KA24de including NAPSZ24, and KAE pistons, and modifying the piston skirts.FAQ page on windage tray, and crank scrapper.FAQ page on electric fan setup using the existing relays offered.FAQ page on ecu swapping from the 5speed manual ecu's to the automatic ecu's (removes speed governor/limiters, and adjusted A/F ratio) FAQ page on different clutch systems, and transmission swaps from the FS5w71C to the FS5w71B FAQ page on tuning NA KA's with a wide band O2 and an SAFC, (beginners learning to tune A/F ratio's) The ultimate FAQ page (post your dyno results FAQ page with list of perfromace modifications)
All FAQ pages need to include in depth pictures, or it's a useless FAQ page...
Modified by Bigvinnie at 4:49 PM 2/27/2007
WDRacing
Got any links for the list you just made homie?
Bigvinnie
WDRacing wrote:Got any links for the list you just made homie?
Only a couple and I would have to redo the FAQ page for NICO, since I have already reserved the right for club240.com (which is over ran by BOTS and administrator changes), it is eventually going to be changing server and forum content....DC sports HOT shot header install...http://www.club240.com/forums/...28557KA24de coolant bypass. Starts on page 2 of this forum..http://www.club240.com/forums/...ber=2
I'm in the works of installing an OBD2 intake mani on my OBD1 engine. I can post picks and a write up just for NICO unless someone beats me to the punch. I removed the SCV's but the JB weld leaks so I'm removing the old OBD1 mani....
WDRacing
So you're cool with me rehosting those pics and copying all the info to Nico yes?
Bigvinnie
WDRacing wrote:So you're cool with me rehosting those pics and copying all the info to Nico yes?
Sure I don't mind. The content has to be edited so that it is only what I gave as descriptive information in the stickie's, any posts that took place other than mine in those threads need to be deleted since they are not NICO content. But you have my consent to rehost the images and my text as long as I get credit for it...
WDRacing
Cool...
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
Argh, thats the worst cam discussion ever... i promise i'll make something better.....
I'll ahve an emmisions remove intake manifold write up done maybe in a few weeks
and throw my DIY adjustable cam gears article, everyone likes free horsepower
WDRacing
That cam discussion may be bad, but its the best we have...I simply can't get involved in a cam swap for a NA motor.
