Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Sat Apr 03, 2004 9:02 pm
Well, I got the starter hooked up, with a direct power feed from the positive terminal of the battery to the terminal on the starter solenoid. The battery is VERY well grounded to the body and every ground I know of on the wiring harness is in it's proper location. I also hooked up the switched 12v power wire that goes to the starter solenoid to its correct wire. Once I did all of this I verified the battery was charged and working fine, then proceeded to test everything to see if the car would turn over. I depressed the clutch, turned the key and heard the starter relay kick over...but nothing from the starter. I then checked for 12v power to the terminal on the solenoid as well as switched 12v whenever the key was turned and verified that it IS getting 12 volts. Then, I checked the ground on the starter (just the body of the starter) it was good. I verified that all the connections were correct and called a friend. We looked at it and he checked everything AGAIN, then we decided the starter must be bad, pulled it out and went to autozone to test it. Well, its just fine. We brought it back and using some spare wire and jumper cables tested it ourselves using my battery, once again verified that it was good. We then re-installed the starter, hooked it back up and whala...nothing, it still doesn't work. So, we take some spare battery cable and connect it from the battery to the positive terminal on the battery to the terminal on the starter solenoid. Check it with the key again...still nothing. Irritated, we decide to take the relay out of the equation and just jump to the switched 12v power on the solenoid to the positive battery terminal. This ellicits a hell of a spark but also gets the starter to work...momentarily. We try it again in about 10 seconds and this time it doesn't work. We pull the starter out AGAIN and this time set it up on the shock tower, ground it to the body with a jumper cable, connect a positive cable from the battery to the starter and jump the battery to the switched 12v. power on the solenoid. Yet again, it works just fine. Currently the plan is just to setup a redundant system, I have plenty of battery cable laying around and so I'm going to hook up a second power cable to the starter and run a ground from the starter body to the car body. Then I'm going to run a second wire from the solder connection of the switched 12v. wire up to the plug for it and splice it in. This way I know it can get all the voltage it wants. However, I really shouldn't have to do this trash, it should have worked just fine. We verified that the wiring was indeed correct (used the voltmeter), then verified that everything that was grounded should be, then verified that when the key was turned 12 volts went to the starter solenoid, and verified that the starter was receiving constant 12 volts from the battery. It should be mentioned that this is just after a rebuild and turbo kit install, I'm putting everything back together and had hoped to start it tonight. It seems theres a problem but I'm thoroughly confused what. When I removed the engine I unhooked EVERYTHING and the only thing still not hooked up is the alternator wiring. Also, there is some other quirkiness with the car, the fuel pump wont come on, and two dash lights stay on after you take the key out and shut the door, the only way to turn them off is to unhook the battery. HOWEVER, they dont turn on until you put the key in the ignition and turn it to ACC. The two lights are the parking brake light and the low fuel light. Thanks for the help guys, I'm at my wits end with this thing.
