One night while driving on the freeway, 20 mile drive home, it was about 90-100 degrees out around 8pm, (Phx, AZ). I pressed the gas and my car wasn't responding like it usually does, i looked down and the temp gauge was up. Apparently my radiator hose blew a hole in it, released all fluids, and car overheated. (*Fans won't turn on, relays are good?Will have question for that at end*) It shut itself off while doing about 70, in gear. I coasted for a while before I REALLY even noticed and threw it in neutral (loud music). I waited and waited for it to cool, starter just whined. I got towed that night.
Now I'm hoping, being that they are aluminum, that my heads didn't warp. The cars cpu just told it turn off when too hot, yes? Now.. a warped head would result in a seized engine, right? would that prevent me from pushing it in gear? because if so, was able to. And was able to turn crankshaft pulley manually. *fingers crossed*
The problem that remains is when I turn the key the starter makes a high pitched whine. I thought it was the solenoid. Autozone tested, said it all checked out. Came home, checked teeth on flywheel as well, they were fine but i hand-turned the crankshaft a tiny bit anyway. Threw it back on there, it caught for BARELY, what sounded like, a partial turn & continued whining.
I heard it could be battery connectors or bad ground, so starter wasnt gettin enough juice. So i trickle charged battery, and even tried to start it with jumpers. Still whines.
I also thought to myself, could the solenoid engage at Autozone and the guy just say its fine, but when put under the weightload of a flywheel, it fails? Resulting in a customer have a thought-to-be perfectly fine, FAULTY, starter?
Could it be as simple as bad mounting? SOMETHING happened when the car died in gear, i don't know the anatomy of a starter.. but hey, please someone suggest something, anything, and I will try it and come back. I will attempt to push start it this morning with my brother. I pop clutch in 3rd/4th for easiest starting cuz of gear ratio and compression? or 1st? k.
Thankyou for your time, I have been stuck here in my apt for far too long and have somethings i need to take care of, it's a big city and too hot to walk in August.
Fellow Maxima Enthusiast,
~Ryan
*If you have enough time or just have a knack for helping people, one last question. Fans won't engage. Checked relays. Switch all fan relays with AC Clutch relay, car started (before accident) with all of them. After the incident I replaced cooling sensor but am yet to run car to see if they turn on. How do you manually engage cooling fans 1 & 2? How EXACTLY to jump relay with paperclip or something, or even bring it inside to test. I do have a voltimeter (not digital) to test, just dont know what it should read. I really need those fans, the heat is murder for my car. Also, hole in thick rubber hose, not at radiator but other end, fixable? Or only replace. Thanks.
