CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.html
Thu Jan 19, 2012 12:59 am
Ive had a minor problem for a while now that I should have fixed by now and tonight it turned into a big problem.
My starter is not "starting" when I turn the key. All the idiot lights come on when I turn the key, but when I turn it to where the engine should crank... there is nothing... just a single mechanical "click" from outside the car.
For about 2 months now, the ODD time I would turn the key and it would do this, but on the second turn, the starter would function fine and everything was good.
Well tonight it took 15+ minutes of constantly clicking the key back and forth before FINALLY it cranked. And then leaving work it took a good 5 minutes of turning the key...
Personally my instincts just point to starter, since it hasnt COMPLETELY failed and does work after many attempts...
There is a pathfinder with the 3.5 in my local junkyard, so hopefully I can try and get whatever parts I need from that.
Any help on where to start would be very appreciated. Thanks guys
