Starter
MarkSilla28
Car: 1990 nissan 240sx s13 with a 1996 ka24de
Does my starter need to be grounded? The videos I've seen the starter only has the power cable to the battery then the signal output
ca18det_boy
It's grounded through the engine/trans
MarkSilla28
Head has to be grounded to fire wall?
ca18det_boy
Head grounded to firewall, block grounded to chassis
MarkSilla28
Hmmmm. Gotta find the ground for the block then....any ideas?
ca18det_boy
Factory location is from the intake manifold-->battery tray-->negative cable.
If it's not there, just buy a short switch to starter battery cable and bolt it to the block-->chassis somewhere
MarkSilla28
Okay cool mine has it on the manifold
MarkSilla28
Okay another question. On the starter where the signal wire is connected there is a flat metal connector. Does that need to be connected as well? Videos I watch I don't see anyone connecting it....but I have a few extra connections and idk where they go. I wish I could post pictures to show y'all.
ca18det_boy
You'll have a lug for your main starter wire (4 gauge or similar) and that's your 12V constant. The spade terminal that you're referring to is your 12V switched connection that tells the starter to engage. So from the factory and at a minimum you'll have 2 wire's going to your starter.
