Yes, the battery is brand new.
Alright. I will have to try this soon. IDK when ill get time to take it off, but im 99.9% sure the starter is bad. so i will try the hammer trick. Hopefully this is all it needs. If the starter is shot, shouldnt the interior lights and stuff still light up though?.. or still no?ZOOMIGUEL wrote:try hitting your starter [ with hammer ] slightly. not hard./.
then go try it . if it does start after you hit it then its definitely bad..
and after trying that i would take it off and take it to autozone and have them check it. they test it FREE!!!
good luck
I just sit there and turn the key back and forth.. sometimes the lights come on and the car will make one click when starting. then other times the lights will not come on and no clicking. If it is wiring, if i were to buy the sr20det with a new harness.. do you think this would fix the problem?ZOOMIGUEL wrote:if interior lights don't turn on that would be a battery issue...
nothing to do with the starter, other than the starter starting car to help alternator charge battery..
but if your battery is well charged and lights dont go on that may just be a wiring issue. but also double check your interior bulbs lol
