starter?
mac_daddy
Car: 92 slicktop n/a
so i went to fire up my 240 the other day and all i got was this winding sound and my motor isnt turning watsoever. could this be a bad starter maybe? it just sounds like the starters not engaging maybe. any ideas?
vancouverbc
Car: 1991 240sx
look up starter trouble shoot in tutorials
mac_daddy
thanks for the helpmy starters fried lol gonna go get a new one tonite
xekushnr
Car: '90 Nissan 240SX Hatch
pull it off and take it to autozone, they bench test starters and alternators for free. then you will know for sure.
mac_daddy
is it possible for the transmission to maybe be misaligned and the starters not catchin the flywheel?
Kalypso
unless you loosened the 10 blots... no way
mac_daddy
i did drop in another motor but i thought i lined everything up and the transmission went in fine and bolted up but it just sounds like my starter isnt engaging. i think im gonna unbolt it and realign everything tomrw...
mac_daddy
just an update, i realigned everything put the transmission back in and its still doing the same thing except now the starter will engage for a second and then the motor stops and i hear a sqealing sound. like metal to metal slightly touching. i dont wats wrong and i just wanna get my 240 runnin again
vancouverbc
Car: 1991 240sx
you have a new starter? are you sure the starter is working right?
mac_daddy
yea i bench tested it myself with my shop teacher, watched everything work and even had it tested at autozone. im totally stumped about wat it could be. maybe a loose connection somewhere? or something binding up? idk
vancouverbc
Car: 1991 240sx
the wrong starter can be like that. not sure if a weak connection or battery would produce those symptoms. you can ground the starter directly to engine. but not sure if any of this would cause your symptoms. if you have your starter off for awhile the interface will rust and you lose your ground.
mac_daddy
well its the same starter that was in it before when it ran, same flywheel too. is it possible to have too much compression in the cylinders? i pulled all the plugs out and cranked it and it turned fine. really appreciate all the help btw
SRprelude
Car: 1996 nissan 240sx se
i had a lot of starter problems, turned out that a voltage drop fom the battery in the trunk to the front of the car damaged the starter connections inside, so i had the starter rebuilt. then the starter relay near the passenger headlight was faulty, so i replaced that too. you definitely need to diagnose it though. btw autozone doesnt do too good of a job testing parts.
mac_daddy
would the voltage drop cause it to squeal? well i tested the starter multiple times with several people including myself and yea i kno wat u mean autozones not the greatest the guy didnt kno s*** haha. but i mean the motor turns fine without the plugs in but then as soon as i put one in it binds up this mite sound kinda stupid but could a bad pilot bearing cause this?
SRprelude
yea my SR starter squealed and howled horribly! it was the bearing or something inside the starter. had it rebuilt by a local shop and it was fine. but problems came back because of my voltage issues
mac_daddy
wait ur bearing as in pilot bearing? or a bearing in the starter?damn gotta hate those voltage problems haha
vancouverbc
Car: 1991 240sx
mac_daddy wrote:wait ur bearing as in pilot bearing? or a bearing in the starter?damn gotta hate those voltage problems haha
the mechanism that engages the starter gear to flywheel can go. i think that is the pilot bearing?
mac_daddy
i wish i could put pictures up but i always thought the pilot bearing was where the input shaft of the transmission goes. it's rite in the center of the flywheel and goes into the block. if u search it on google images u can see its just this little ring that sits in the motor.
but now ive had some ideas of it maybe being the main bearings but i really dont kno. this cars just been a nightmare since i pulled the motor haha
