starter
nightkid86
Car: 97 S14 SE
in the process of a transmission swap. Before reinstalling the starter we are trying to see if it will work with our wiring job. We have wired up as much as we know to, but the starter refuses to turn with the ingnition. Also we wired the starter directly to the battery, and it would still not turn.
there is a sensor on the top of the starter, don't know what it does but we tried hooking it up and still nothing. Anyone know what our problem might be?
vancouverbc
Car: 1991 240sx
Sound like a bad starter if you tested it directly to battery.
base9se
Car: '95 240sx
must be a bad starter solenoid (engages the gear/plunger)
nightkid86
Car: 97 S14 SE
it was a bad ground. Got everything taken care of and completed a 5 speed swap
vancouverbc
Car: 1991 240sx
Thanks for reporting back what happened. Wish more people would do that.
benemorius
Car: s13, s13, eg, e36
vancouverbc wrote:Thanks for reporting back what happened. Wish more people would do that.
