Starter Solenoid
dancad
I have a 1992 240 SE that suddenly quit starting. I checked the voltage at the battery and have 13 + and also checked the voltage at the main post on the starter and also had 13 volts
When my daughter turns the key, the voltage to the starter solenoid reads anywhere from 7 to 9 volts
Any ideas what could be causing low voltage to the solenoid ?
Thanks
vancouverbc
Car: 1991 240sx
I am really rusty on electrical but it sounds like some kind of voltage drop. I would check the interlock relay and ignition switch for voltage drop. or maybe the wire is grounding somewhere. test with volt meter for voltage drop along the line or maybe a test light or bypass with wire to see if volt drops disappears.
see starter tutorial in my signature
tercel drifter
Car: sr20det s13
that is normal to see a 9volatage drop at the starter. anything less and it wouldn't crank. If there is a 9v drop across the starter and it's not cranking you'll need new starter.
vancouverbc
Car: 1991 240sx
tercel drifter wrote:that is normal to see a 9volatage drop at the starter. anything less and it wouldn't crank. If there is a 9v drop across the starter and it's not cranking you'll need new starter.
i assume you mean the the wire is connected to the starter. i was assuming he had disconnected the wire going to starter before measuring voltage.
vancouverbc
Car: 1991 240sx
see the starter tutorial in my signature. if you have 12 volts with wire disconnected at starter you need to hit starter etc etc per tutorial
