Starter solenoid going......i think?
got_boost702
Car: racing, cars, snowboarding
I turn the key in my 95 sr20 powered 240 and nothing happens but if i hold it for ten seconds it will crank over no problem. Sound like the starting solenoid?
If so, where can i source one from?
fantabulous
Car: s14
did you check that single slide on connector on the starter? i've had that vibrate loose a couple times and had nothing when i tried to start it.
Nismo31
my car wont start for sh1t now. i thought it was the starter so i replaced it and still has the same problem..blows!
mss5413
Car: Nissan 240sx
maybe your ignition switch is going out. I know that sometimes I have to turn mine twice to get it to start.
Chingon
Car: 1991 and 1992 hatchbacks
check the starter relay..it's on the firewall close to the battery. (blue in the ka) hit it a couple of times and see if that helps.
