NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Aug 11, 2005 6:34 pm
Try wiggling the shifter or put it in N when you try to start it see if it starts then.
Also your car might have a factory alarm that is partially disconnected so in that case unlock your passenger door with the key then try to start it. The reason I say the passenger door is. If the system had been partially disconnected there must have been a reason, the usual reason is the drivers lock cyl alarm switch is broke.
