I got it towed back home, got a new starter to replace the faulty unit, and set to work.
Those of you who have replaced a starter on these, please stop laughing at me now, thanks.
So, it definitely seems as if I have to remove the rack and pinion unit in order to access the starter. So far, I've gotten the outer tie rod ends to break loose (dear God, that took some beating/PB Blaster soaking), gotten the power steering fluid drained to avoid messiness, gotten the four bolts holding the rack in place removed, and loosened the U-joint attached to the steering column (marked with paint already, one less screw up for me to screw up).
My issue at this point is that I cannot seem to maneuver the rack in any meaningful way in order to get it out of place so I can access the starter. I must be missing something, but I cannot see what it would be. I've read a few posts on here so far, but none have mentioned my specific set of circumstances.
Has anyone else done this themselves, and can tell me what the heck I'm doing wrong so far?
