STARTER really need help
joshcereal
ive searched and searched
Ok so ive replaced the battery replaced the starter replaced the terminals replaced the wires checked around nothing seems to be damaged and ive gotten the starter tested works great. so i dont know whats going some things say the starter relaty well i found a blue thing thats cles to the battery and it seems in good order.... please i reall need to get this worked out due to im selling the car before i go into the army so any suggestions will be great
ps if anyone wants to buy the car with this proplem ill sell it for 500 dollars off what im asking wich is 6000 thosand so 5500 if you want it now
thanks much
Modified by joshcereal at 8:53 PM 6/22/2007
JeromeS13
Car: 2008 Subaru Impreza STI
I haven't seen a problem stated here. You said you've replaced some parts, but what are the actual symptoms and problem? Please, be specific.
-Jerome
joshcereal
ahh sorry bro
well it wont start when i go to turn it over all i get is a click wich leads me to believe my starter is out well replaced that and it did the same thing was like mabye i got a crappy starter so went to autozone had them test it works fine so put it back in the car its still just goes click click well someone siad it was a bad battery so replaced that well nope still clicking just my light are a little brighter. well i replaced the connections for battery and i know the lines are good since i replaced those when i did the battery relocation. i checked all the fuses ther fine and dandy. accept my ac fuse. well now i know people have siad you can try to jump the relay really dont know how to do that ... also i bought the engine pre droped but fixed alot of whats wrong and thers a red wire going from blue relay to a fuse really dont know what that is ethier..... so i stand ive checked and changed alot of the stuff and have a wierd wire coming off the what ibelve to be the starter relay...... so all i want is to get this baby stated and get it off and out the door so i can save the money while in basic and with my signing bounos and get me my 350z
JeromeS13
So, have you seen this engine run at all? Can you jump or push start it?
-Jerome
joshcereal
yes the engine was running about 2 weeks ago it started when i went to apple bees came out and it wouldnt start so i had it towed home and ive had this proplem ever since... i can try and push start it and it starts up kinda but i really cant get it up to speed to really give it a good push start but i have got it to do the low ruble like it wants to start when i push it ........
Modified by joshcereal at 1:56 AM 6/23/2007
joshcereal
please
PhopsonNY
Car: 1989 Nissan 240SX
Couple of things I have had problems with...Check your ecu is connected properly and has not come loose....
Also, you may have a fuel supply problem... maybe a new FPR or is your pump up to speed?
Just some random thoughts
cheers
joshcereal
fuel pump is good might replug my cpu mabye that will work
FAST-DATSUN
if the starter and battery are good check the grounds. unhook the ignitor and remove the spark plugs and see if the motor cranks over, you have have a hydro lock do to blown head gasket
