starter question
mini-x
i just did an sr swap, and turns out that the flywheel, and clutch isnt the stock one. the flywheel is actually smaller then the stock one. so my question is if i buy a stock fly wheel and an upgraded clutch would i need to buy a new oem starter?
exode
Car: 90' 240 w/ 400hp SR20DET
stock flywheel and upgraded clutch = same starter. Was the starter on the motor smaller than an oem one? shouldn't be... Your current starter should work fine. Fyi, KA Starters (maybe just the sohc, do a search to confirm) work with a minor amount of wiring.
