starter problems?
mordakibojangles
Car: 89 240sx
I have a 89 240sx auto with the ka24e. The car fires right up most the time, sometimes it doesnt tho. When it wont start i hear a clicking noise. When its doing that i usually just try to start 5-6 times and eventually itll fire right up. Need help figuring out wheter its the starter or just the relay. Thanks all help apreciated.
Rambo24o
Car: S13 240sx
If the realty clicks its good it should click only ones maybe ur battery and the clicking noise u hear is coming out of the started trying to turn over but not enof battery current
kouki munster
Car: 97 base 240
Connections between the battery and the starter, check them, clean them, and replace any wiring that is heavily corroded. It could also be the ignition switch starting to show its age as well.(I've seen this happen to a fair number of 240's)
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I second that.
I had this problem. I swapped out starters, solenoids, and it was still clicking. Turns out it was my POS West Co. battery. Now, I gotta a big a** 750CCA Duralast Gold in the trunk FTW. Check those cables too! Load test those cables.
alms24sebring
'04 Nissan Sentra SER SpecV
Fast clicking means its a weak battery or corroded cables. a single click means the starter is not engaging.
^ lol I have a "Werker" battery....
