starter problems
bersh240
so my starter or smthin makes a screeching sound instead of turning the engine over sometimes. and it happens at the worst possible times. like after stalling on giant hill thanks to jumping in and out of 20 different cars. it just wont start just screams at me.so before i lay out under the thing in the cold what could be the problem?i found where to get starters and stuff but couldnt find anything like this..
bersh240
soo... nobody cares?..
awsome.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
man up. get the starter out and get it tested.
float_6969
ca18detgabby wrote:man up. get the starter out and get it tested.
Spoken like a real woman.
bersh240
well whats happening is the drive gear isnt engaging the flywheel.. im just looking for a way to fix this. i know the starter works. just isnt engaging. soo... no im not gona "man up" and do something that will only tell me what i already know... just want to know if theres a way to fix it without replacing the startedany ideas?
ca18detgabby
03 Infiniti G35
your starter LIKELY isnt fully engauging and only going part way. Thus you get that lovely grinding nose instead of full engauging and grabbing the flywheel.
teeth on the flywheel or the starter are also being damaged each time it makes that sound.
btw it not fully engauging means it ISNT WORKING.
bersh240
oh.. soooo.. this IS gona get expensive..so replacing it soon is prolly a good idea? to prevent major damage to the flywheel?
2ndcar
Car: 1991 240SX White 1991 240SX Gray 1995 Civic
I don't know if you're up to it, but pull the starter apart and try cleaning it. Sometimes grease can get on the contact points. Its not hard to pull it apart its just a couple screws at the back and it'll pull apart. Wipe any grease off and take a fine grit sand paper to all the copper parts, it should help.
