evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Jan 07, 2008 10:14 am
could be a distributor, ignitor, or even the ecu, unfortuantely these are low voltage square waves difficult to diagnose without special tools, if you can locate a known good distributor and or ignitor you might try swapping asn see if one or the other fixes it, unless you have access to a logic probe, in which case check for the 2 different signals fromt he distributor and the pulse signal at the ignitor
